99 civic Ex smokes when you throttle
Old Oct 9, 2018 | 01:20 PM
wind82's Avatar
Default 99 civic Ex smokes when you throttle
I bought a 99 civic Ex coupe with a 1.6l d16y8 engine at an auction . On start you hear a low tick close to the distributor , when you give the car gas it smokes for a second then stops until you stop and give it gas again . So far i changed the oil , filter ,pcv valve/ grommet ,spark plugs , valve cover gasket , distributor and o2 sensors either for code related faults or no start conditions . The car has no misfires , hesitations and all cylinders compression test within 5 psi of each other at about 180. can anyone tell me what could cause the tick and smoke ?
Old Oct 10, 2018 | 06:23 AM
Kevs02Accord's Avatar
Default Re: 99 civic Ex smokes when you throttle
leaky valves?
Old Oct 10, 2018 | 04:35 PM
wind82's Avatar
Not sure , i removed the timing cover and found the belt flapping around like crazy . i think i'm just gonna yank a head from the junk yard and swap that in and replace the belt . If that doesn't work i will come back crying and begging for suggestions.
Old Oct 12, 2018 | 09:14 AM
if you pull the head why not check clearances first before getting another head?
Old Oct 12, 2018 | 01:58 PM
wind82's Avatar
Because i can get an entire working head from the yard for around $40 . I already did a valve lash adjustment ,pcv system replacement ,checked the oil level, cleaned all the deposits out of the throttle body , intake hoses and intake . The only options i can see left involve parts i can't source local or have the tools needed to replace them with.
raverx3m
10
Oct 14, 2013 04:49 PM
S_F
34
Nov 22, 2012 10:54 AM
vegas
Dec 15, 2008 04:26 PM
Xscort
11
Jul 28, 2008 07:29 PM
shortlid
Jan 10, 2008 05:44 PM
