Ef sedan b18b1 swap no spark test light is on at the ignition switch
Old Oct 9, 2018 | 07:33 AM
vcerna's Avatar
Default Ef sedan b18b1 swap no spark test light is on at the ignition switch
Hey guys,and girls I have a ef sedan with a b18b1 ls 5sp obdo , dpi to mpi .removed the engine to rebuild it.got the motor done installed and I go to start it and no spark . So I checked fuel good, battery good grounds good (note: car ran before. ) bought a new dizzy .double checked my grounds .my dizzy wires were brittle and couple of those wires broke ordered a new plug for it hooked it back up color matching orange with orange, skinny white with skinny white and so.. still no spark. Checked my dizzy and ecu with another car that car ran so I'm assuming something in the dizzy plug but I check 4 or 5 times the are correctly color matched the wiring harness was taken off and inspected and repaired installed it again and nothing...... how ever now I have a spark plug tester ligjt with the key on engine off,just before the engine is set to start all my dash lights are on like normal the sparkplug light goes on I go to crank it and nothing I can make the spark plug light tester go on and off with the ignition switch. I'm lost on what it could be any help will be appreciated sorry for the long content.
Old Oct 9, 2018 | 01:16 PM
Marcos Barrios's Avatar
Default Re: Ef sedan b18b1 swap no spark test light is on at the ignition switch
sounds to me like you got two wires installed in the wrong place
i cant tell you witch ones
i dont know
but to find them your self
trace them with a light tester at the dizzy and see where they go on the ecu
and when doing this make sure the harness is unplugged from the ecu
do not test for volts with the ecu connected
good luck
let me know if you want to know witch wire is what on that ecu harness
you can find that info on my build thread
marcos new work car 90 sedan
page 4
Old Oct 9, 2018 | 01:24 PM
vcerna's Avatar
Awesome thanks I will do that I'll let you know
Boosted96gsr
Jan 9, 2012 08:04 PM
Nooch
11
Jan 21, 2011 10:22 AM
Mik2006
Jul 31, 2009 02:54 PM
Dave_Dc2
Jan 16, 2009 03:05 AM
Freeltec
Apr 24, 2006 09:41 PM
