Fuel Filter Washers
Old Oct 7, 2018 | 06:43 PM
zturek's Avatar
Default Fuel Filter Washers
2000 Honda Civic Coupe
I have a new fuel filter total 3 washers
Two large and one small
I know the two larger go to the top bolt
I don't where the small one goes
Old Oct 8, 2018 | 03:08 AM
mk378's Avatar
Default Re: Fuel Filter Washers
The small copper washer is for the small bolt that closes the test port in the top of the main bolt. If you did not remove the small bolt you don't have to replace the washer.
Old Oct 8, 2018 | 05:59 AM
zturek's Avatar
Old Oct 10, 2018 | 06:28 AM
Kevs02Accord's Avatar
heres your answer.
Old Oct 10, 2018 | 05:51 PM
egsleepercivic's Avatar
It does look like the small washer is used in you application, it pressure release is probably on the fuel rail in your car.
Here is a 95 teg that has the pressure release on the filter, yours doesn't have it
Old Jul 24, 2022 | 03:05 PM
Twiztidfaye's Avatar
Anyone know the size of the washers by any chance
calvin924597
May 28, 2010 09:55 PM
zracer240
May 7, 2005 04:32 PM
cvc323
Jun 29, 2003 11:09 PM
[HrZn]4life
Mar 17, 2003 03:37 PM
Orig
Oct 28, 2002 05:09 AM
