Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Low & High Beams (Headlights) - Weird Behavior (Not Working)
Old Oct 6, 2018 | 02:09 PM
smaciel's Avatar
Default Low & High Beams (Headlights) - Weird Behavior (Not Working)
Hello,
I am having some issues with my headlights. I have a 2003 Honda Civic (LX Trim), manual transmission, 1.7L engine.
When I turn the combination switch to the low beam setting (2 clicks forward), the high & low beam filaments turn on (both sides). When I push the combination switch forward/backwards (the high beam setting), the headlights turn off (both sides).
I have checked all the fuses & relays and they all work. I have checked the lightbulbs using a power supply and they both work.
I have not checked the wiring yet because that is a lot more effort to do and was wanting to post here to see if anyone can think of anything else I can check before I do that? I have a Haynes Repair Manual and have the schematics (the relevant one is shown below):
Any help would be greatly appreciated!
Thanks,
Sheldon
Old Oct 9, 2018 | 09:29 AM
NDNV's Avatar
Default Re: Low & High Beams (Headlights) - Weird Behavior (Not Working)
I would check the combination headlight switch for failure. See the attached for troubleshooting before buying a new one.
Old Oct 9, 2018 | 11:27 AM
thisguyaves's Avatar
So something in the switch is turning on low and high at the same time. That, or you have the wrong headlight bulbs. Your bulbs should have 3 prongs, that would be the easiest thing to check.
Old Oct 29, 2018 | 11:45 AM
civichxtreme2's Avatar
There was actually a recall on this several years ago, some 01-03 Civics had issues with the connector on the back of the stalk burning out. Might be worth looking into.
-Brian
SteezeDisease
Mar 5, 2013 07:38 PM
VTECROAR96typeR
Feb 9, 2009 05:35 PM
Chewy Built !
Oct 4, 2006 08:26 PM
fathergoose
Sep 19, 2003 06:13 AM
J Money
Jan 12, 2003 06:24 PM
