EJ1/EG B16a swap instrument cluster???
Old Oct 4, 2018 | 09:05 AM
Enlight3nd0n3's Avatar
Icon5 EJ1/EG B16a swap instrument cluster???
Hello,
I am currently trying to do a b16a engine swap with a 1994 Civic coupe (EJ1) and am having an issue with options for the instrument cluster. I'm not a fan of small clusters hanging around the inside of the car, and want to keep my gauges within the area for the original instrument cluster. My issue is that the B16a has a much higher redline than the original d series engine, which means that the tachometer that the car currently has wont match up. Any suggestions as to where I could find an Aftermarket instrument cluster that will work with the higher revs of the B16A?
Old Oct 4, 2018 | 09:10 AM
LiteraCola's Avatar
Corvette Forum Member
Default Re: EJ1/EG B16a swap instrument cluster???
You could always swap in an EM1 cluster, or go hardcore and stick an S2K cluster in there. Search search search.
Old Oct 4, 2018 | 09:16 AM
hybridnorth's Avatar
Buy the omnipower tach, replaces the stock tach and has different redlines and an adjustable shift light
Old Oct 4, 2018 | 11:43 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This.
gunpointllam
Jul 10, 2016 10:41 PM
mugenpowered
12
Apr 29, 2006 02:01 PM
excaliberneon
Mar 31, 2004 02:26 PM
Type S
Sep 10, 2003 10:58 AM
