98 ek hatch with a b20 ecu issue
I have a 98 Ek hatch just did a b20 motor and running rite now a friend p28 but he need it so I got a socket p06 ecu and about to get a chip for my motor will that work Perfect or no cause a lot of people say to get a p28 chip out compare to any other ecu why and what’s the diff please help lol Thsnxk
have one but stock and car run bad xause I got some modification so I quess Thars why but rite now I’m running a p28 and car runs good but wanted to get a ecu chip out so my friend gave me a socket already p06 for free and only I need a chip but was making sure the ecu will work good with the car and motor before I get a chip
Cause I have a lot of friends with socket ecu but just wanted to know which ecu would be better to get a chip for or would all work good with a chip for my motor
Now, if in the future you intend to swap to a DOHC VTEC head, then you may want to use the P28 ECU now with the ability to grow in the future. You can also "upgrade" your P06 to P28 specs by adding the internal components to operate VTEC. This can be done to a P74/75 ECU as well. The circuit paths are there... you merely have to add parts to make it work. So there is no "Best" ECU to answer your question... since your chip will have the programming to operate your engine and the stock programming is being ignored.
Thanxk for the information and it’s a b20 high compression and aem fuel rail and regular and have the psi at 45 and still run bad keep choking a little on low rpm but I bring it about 55 and 60 run better but then I smell gas and my muffler smoke and choke alitrle on high rpm now so I had a stock p28 and just order a brand new p28 socket and chip out from clmmotorsport so hope wirj the chip out ecu and having someone have the psi number rite shoukd be better I think I don’t get which psi it shoukd be say to 43.7 but when I do choke a lot under 45 so maybe ifs the ecu or cause I have a skunk 2 mani with 70mm tb maybe it’s that
put in an unmodified p75 ecu or have your p28 flashed to stock p75 maps.
Verify your tps is calibrated and that your map sensor is good.
Enjoy your now fine running vehicle.
