Motor Fan = 93 Honda Accord
Old Oct 3, 2018 | 12:11 PM
Kosmic-nut's Avatar
Default Motor Fan = 93 Honda Accord
If the heater fan goes out a little at a time, then finally quits, is that the failure of the motor or a switch or something else?
Old Oct 3, 2018 | 04:21 PM
brakedrum's Avatar
Default Re: Motor Fan = 93 Honda Accord
If they are up to spec, the thermo-switches that control those fans are very precise in reading temperature. It is not unusual for them to cut on and off quite a bit. Even the switch that makes the fan run to disperse accumulated heat after the engine is off might cut in and out a few times before it is happy with the temperature it is sensing.
If you have AC, do both fans run while you have the AC on?
Old Oct 3, 2018 | 05:02 PM
Kosmic-nut's Avatar
The fan does not function for either AC or the heater. Actually, the AC went out a few years back.
The entire AC unit was bad, and I didn't want to invest in a new unit. The heater fan went out
just a few weeks ago, but was working very weakly before that.
Old Oct 8, 2018 | 09:54 PM
Kosmic-nut's Avatar
The fan worked with both A/C and Heater, then little by little it grew weaker, and finally quit.
Is there a definitive answer for the origin of the failure?
angrysmileyface
May 12, 2018 11:24 AM
95wagon
Jun 11, 2014 04:05 AM
geribair
Jun 7, 2014 11:18 AM
axionm1k
Jun 14, 2008 02:16 PM
