Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
CV Axle heat tape.
Old Oct 2, 2018 | 01:48 PM
Driven's Avatar
Default CV Axle heat tape.
I've seen a few cars running around with CV boots with a reflective tape on it. The only tape I can find only really works on metal surfaces... anyone have a source for tape that'll stick to the rubber CV boots?
Old Oct 3, 2018 | 06:39 AM
ross2004's Avatar
Default Re: CV Axle heat tape.
I've seen tape around ball joint boots, but never CV boots. You could always but the tape on and then zip ties around the boot/tape to keep it in place. Honestly though, I can't see it doing much. If you're overheating your CVs, you probably need to cool your brakes better.
Old Oct 3, 2018 | 06:49 AM
Driven's Avatar
It's not from brakes... it's from a turbo and all the radiant heat from that. I've been on a "heat-wrap everything" kick.
I haven't had a problem yet since I'm running driveshaft shop axles with their road race boots/grease, but figured it couldn't hurt to heat tape the boots too. Fixing problems that doesn't exist, kinda thing.
Old Oct 3, 2018 | 08:14 AM
Colin's Avatar
I haven't tried it on rubber, but in my experience on other surfaces this stuff sticks REALLY WELL.
https://www.homedepot.com/p/Nashua-T...7792/100030120
I imagine that even if it doesn't stick too well to the rubber you can get it stuck to itself and it should stay around the boot without flying off.
Old Oct 3, 2018 | 10:02 AM
90civichbsi's Avatar
With the amount of movement, flexibility and RPMs I can't imagine anything that will stick to flexible rubber for long. I use the tape linked above to keep my wheels weights from coming off, but that stuff is not flexible at all.
I don't see ambient air being as much of a problem on CV axles as brake heat transfer through the hubs would be. If you really think it is, what about just ducting some fresh air in from the front bumper?
EFs are pretty space limited for brake ducts in the wheel wells so I am doing something like this to direct air towards the hubs and brakes:
Old Oct 3, 2018 | 10:33 AM
ross2004's Avatar
^ put a zip tie(s) around your CV boot. You don't want it to balloon out and get cut on that deflector.
hcaulfield57
11
Feb 5, 2017 09:19 PM
chris89
Transmission & Drivetrain
Aug 28, 2015 09:51 PM
Rooftop voter
Suspension & Brakes
Apr 9, 2007 08:38 AM
Mavrick
Nov 11, 2005 11:14 AM
4doorH22
Apr 7, 2002 08:06 PM
