1998 Civic misfiring engine. Don't know the cause.
Old Oct 1, 2018 | 07:07 PM
Aphix's Avatar
Default 1998 Civic misfiring engine. Don't know the cause.
On Saturday I was driving back from my cousins house. Same route, everything normal. I realize I'm doing 80 & decide to push a bit further & get to 90. However, as I'm slowing down to the speed limit, I notice that my check engine light is blinking.
Now I know what that means & I pull over to see what's going on. I turn the car off & on & try to drive it. Around 30 mph, I start to notice a loss of power & I hear a popping noise every 3 seconds or so from the exhaust. Knowing it's a misfire, I get my car towed home & try to find out wrong. I do the general misfire test & find out that cylinder 4 is misfiring. Thinking it's my spark plugs & wires, I go to buy new ones & change them. Unfortunately, that doesn't fix the problem. I'm pretty sure my fuel injectors aren't the cause. Could the distributor be the cause? Did going that high of speed cause something to go wrong?
I'm in the position where I want to fix what's wrong but I don't want to waste money on replacing something that doesn't need replacing. I'm only 20, money is pretty tight so any help is greatly appreciated.
Old Oct 1, 2018 | 09:54 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: 1998 Civic misfiring engine. Don't know the cause.
buy/rent a compression tester. you can move the wire of the misfiring cylinder to another and see if it follows
Old Oct 2, 2018 | 04:28 AM
mk378's Avatar
If you're saying that #4 is completely dead, you could have a burnt valve. That would show on a compression test. A quick test you can do with no tools or no money is to disable the ignition by unplugging the harness wires (not the spark wires) at the distributor, then crank. If it doesn't sound normal, having a "once around" speed up of the starter, there's an internal problem with the engine such as a burnt valve.
Old Oct 2, 2018 | 09:29 AM
Aphix's Avatar
Cylinder 4 has a spark but i would say it's weaker than the others. Would that make a difference? Also, I get a smell after I turn on the car, I can't determine if it's burnt oil or the smell of fuel.
Old Oct 2, 2018 | 11:28 AM
diagnose.
madcat501
Honda Civic (2006 - 2015)
Jun 29, 2010 05:43 PM
IntegraUC
Feb 16, 2009 08:30 PM
89bluehatch
Feb 11, 2007 08:16 AM
bpowa
Feb 20, 2005 07:39 PM
ZoNe_HKS
Sep 17, 2002 04:19 PM
