hey, I need help on couple things for my car (93 Civic LX). I have basically fully restored this car but I need a couple things still.
rear drivers side door pillar trim. It appears that they have discontinued it OEM so I have to go aftermarket ebay or a faded junk yard one. Im having trouble finding the appropriate clips for it.
front driver side window seal. Im not always the best at looking at parts diagrams but im thinking its called the sub seal part # 72365-SR4-A03?? im mostly tired of hearing the wind hitting it and how it gets bunched up when you roll the window up.
im not even sure what this is called. is it a window guide? there is just rubber that has chunked off most of my windows.
Like Tony said, wrecking yard is your best bet. I had the same issue with the outer seal(no one knows what it's actually called) which led to a lot of problems with the regulator. I bought a whole door for 40 bucks and tore it down.
Picture 1: I don't know what it's called for the rear door on your car, but on my 1999 Civic's front door it's called Front Door Sash. I guess maybe it's called Rear Door Sash? Pillar Trim?
Picture 2: Window run channel
Picture: Left door Molding Assembly, or, Door-belt Weather Strip, or, window trim, or, Belt Molding
