99-00 underdash srs wire hardness yellow wires
Old Sep 25, 2018 | 10:41 AM
WAUKEENEM1's Avatar
Default 99-00 underdash srs wire hardness yellow wires
Need your help guys....got done putting dash back on after replacing heater core but i cant remembered or figured out these last 2 yellow srs connectors goes to.
anyone with a 96-00 civic, can you take a pic of it where it goes to...
thnx much appreciated
Old Sep 25, 2018 | 11:35 AM
sumdewd's Avatar
Default Re: 99-00 underdash srs wire hardness yellow wires
I am fairly sure they go in those two plugs on the fuse box. Someone please chime in so my input doesn't blow this HT'er up, it's been a while since I've messed in the fuse box area of an EK. I believe those wires have to do with resetting the SRS light.
Old Sep 25, 2018 | 11:42 AM
sumdewd's Avatar
Just checked the wife's 96 LX. The right hand one I marked on the fuse box is the dummy plug that holds the 2 pin connector to reset the SRS light. The left hand one I believe is an actual power wire, hence the huge clip.
The right yellow wire should plug into the right red circled plug, and vice versa. I dunno where the crap the other dangling grey connector goes.
Old Sep 25, 2018 | 01:11 PM
WAUKEENEM1's Avatar
Ok...so after looking at the fuse more closely...i think i figured it out...
yes, the 2 pin clip is the reset dummy one
The big clip goes to the fuse box...
It was confusing because one of clip goes to a yellow clip on top of fuse box so i thought the rest has to go into a yellow clip too
Btw, the other grey clips goes to the mirror control n sunroof
thnx for the help guys💕👍
Old Mar 13, 2022 | 03:05 AM
VaTTiC0's Avatar
Hey man !
I restore my civic ek 4 and like you, I have the same plug wich puts into the mirror command.
However, it isn't fit on mine... Apparently I have a 10 pins plug for this but I have the 5 plug....
Is it possible to check with a picture if you still have it since you asking help 😅
spat12
Sep 1, 2018 02:56 PM
hondacivic1229
Honda Civic (2001 - 2005)
Mar 22, 2010 03:54 PM
grape1161
Aug 30, 2009 07:59 PM
oryanh
Mar 27, 2003 01:13 PM
ace1875
Jan 12, 2003 12:44 PM
