my ac was taken out by the previous owner while trying to reinstall it seems the wires that connect the fan and the compressor clutch were cut can I purchase these separate or should I just cut and splice my compressor is a sanden and has a little metal tip on the wire can anyone put a picture of what the connectors look like so I can try to find them
I replied to your other AC thread a few days ago with some very helpful information on getting your AC sorted out. Also it may be helpful to you and others trying to help you, to keep all of your AC related questions in one thread.
Your Sanden is a single wire with a bullet connector from the factory. The other end will be a wire with rubber coated connector on the end.
Sorry for inconviently spreading it out I don't use forums often and don't really know the etiquette.
but I did get the ac compressor and retro fit on plus I found the correct oil/freon amount I need.my new problem unfortunately is that the connector the bullet connector plugs into seems to have been cut off along with the connector to the condenser fan being my first attempt at any ac repair I'm pretty nervous so I don't want to mess anything up. I also may be over looking this cable if anyone knows what part of the wiring it come from it would be a grea help!
It doesn't matter what kind of connector you use. The factory compressor connector is a bullet type. Those connectors are available at any auto supply. There are no specific replacement parts available for the fan. You might be able to find something used on eBay if you really wanted to. What is important is the splice you make is a good one. The fan circuit carries some amps and will burn up a bad connection.
These are the wires in assuming are for the ac line I'm not even sure they are correct and if not where should I look because these appear to be the only wires not running to anything and that plug goes to an ac line
The connector goes to the pressure switch below the battery tray. The red wire is the only wire that goes to the compressor clutch. The compressor obtains its ground from the mounting point.
Repair and extend all 3 wires. Plug the red wire into the compressor. Make a new connector or solder the blu/blk and blk wires directly to a condenser fan motor (if applicable). Be sure to check for correct polarity before you make the final connectors. The fans should be pulling air from the outside and in toward the engine bay. Use new wire loom and zip ties to keep the wires from hitting the fans as they run, or getting burnt by the radiator.
Check the wiring under that wire loom a little further. It looks like the black wire is chewed up and has exposed insulation. You're gonna want to heatshrink those suckers.
