Suspension & Brakes Theory, alignment, spring rates....
Did i ruin my ABS pulse ring(Wheel bearing) 08 TL-S (PIC)
Old Sep 22, 2018 | 05:12 PM
B_Swapped93's Avatar
Default Did i ruin my ABS pulse ring(Wheel bearing) 08 TL-S (PIC)
Picked up some TL-S knuckles. Long story short, drilled out ABS sensor hit the integrated pulse ring with the drill bit. Below is the worst spot. How picky is the sensor? would that nick render the whole wheel bearing to be toast? I do understand how it works by "counting" the notches, which is why I'm worried.
Old Sep 25, 2018 | 06:50 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: Did i ruin my ABS pulse ring(Wheel bearing) 08 TL-S (PIC)
If I'm not mistaken, that's not the pulse ring. I could be wrong since I'm not super familiar with those knuckles, but in every car I've ever worked on, Hondas included, the ABS ring is on the axle, not the wheel bearing. Also, I don't see any distinct bumps on that to begin with, that looks like the wheel bearing seal.
Old Sep 26, 2018 | 04:42 PM
The TL is supposed to have an integrated magnetic "tone ring" in the wheel bearing according to several articles. The fine little notches are there despite them being hard to see. I know a lot of the older Hondas have the ring on the axel but the TL is not as lucky. I;m just wondering how picky the sensor is, I took the knuckle to Honda and one of the techs there said "try it". not the best advice.
Old Sep 26, 2018 | 07:41 PM
SpiderX1016's Avatar
Yup they're finicky. I've seen a tech here ruin one cause he wiped it with a rag and left metal flakes on the magnet. Didn't figure it out until he put everything together and drove it.
So I would replace it. Especially now since the knuckle is out already.
Old Sep 28, 2018 | 07:52 AM
DumpdEJ6's Avatar
I apologize for giving incorrect advice. Learned me something today, thanks! Good luck with it.
jason_SIR
Mar 25, 2014 01:49 PM
DACteg
Jun 9, 2008 07:29 PM
youdontknowmeeither
Dec 20, 2006 08:50 PM
alexdog69
Oct 18, 2004 02:43 AM
