Rear control arms/balljoint end sit about 3 inches above the tire...is this normal?
Old Sep 19, 2018 | 03:53 AM
josh2415's Avatar
Default Rear control arms/balljoint end sit about 3 inches above the tire...is this normal?
I have a 91 4-dr. I replaced the rear shocks & control arms w/ ball joints a few years back. it raised the rear end of the car back to original ride height, I believe. It struck me as odd that the of the arms sit so close to the top of the tire now, unless that's normal. I was considering putting a larger wheel/tire package on it, but was concerned that the tires may rub, unless the arms would raise up with the additional 1 or 2 of the larger diameter tire, and stay the same distance away from the tire. Anyone else ever have this scenario? Any input is greatly appreciated.
Old Sep 21, 2018 | 11:33 PM
GhostAccord's Avatar
Default Re: Rear control arms/balljoint end sit about 3 inches above the tire...is this norma
Yes the ball joint end of the upper control arm is rather close to the tire. In saying that, you can install a larger diameter tire without any control arm contact issues What you have to watch for his how wide you go.
Dave_Dc2
May 13, 2008 03:56 PM
ek9=]
Nov 18, 2007 12:56 PM
Thrashed Civic
Jul 23, 2007 05:55 PM
DC Sports EJ8
Oct 10, 2003 11:45 AM
