Lightening a Stock Flywheel.
I was just wondering if anyone has lightened a stock flywheel from a 92-95 SI. And how pounds or what's the most that can be taken off. I'm staying all motor SOHC if that helps any. Any info would be helpful..
I believe that they are right around 18 lbs. Does anybody know where you can take a flywheel to have this done? Local auto parts store, machine shop? I have heard that it has to be balanced also, is this true?
yes its true about being balanced INLINEFOUR.com offers a good service for 100 bucks plus shipping....and i've heard that its safe to keep them around 14...but you can go lighter
What about a Type R fly? I think they are 14 or 15 lbs. to start. Can they safely go to 12 lbs.?
i heard about someone doing this and it shatter, and tore his legs up as the flywheel shatter and flew into the car, i'm not sure how light he did, but that thought is just a bit scary....
My local machine shop said they could lighten my OE flywheel but they need to know exactly where to remove material. My guess is to grind down the outer lip till it is gone, then start shaving the larger ring of metal under it (as indicated by the arrows below). Can somebody enlighten me; is this correct?
I was just wondering if anyone has lightened a stock flywheel... Any info would be helpful...
Shaving the surface of a stock steel flywheel is an old money-saving trick, but this is generally a poor choice. Like all engine and transmission components, the flywheel is a precision part, albeit heavy. Simply shaving surface material will only serve to weaken the flywheel. Because it already takes a beating buffering the force generated by the engine, weakening a flywheel can only result in failure.
It's your life; do what you want, but, this is the wrong place to skrimp IMHO...
but i still can't get anyone to tell me if this is the correct place to take off material. bone's flywheel looks like it was taken down in steps or something?
slowsleeper
Apr 29, 2004 05:56 PM
