Front Bumper
So my integra is a 1995 LS Sedan, and the right side of my bumper is hanging and the turn signal is also out a bit. My mechanic said to replace the whole bumper but I had a few questions. Would replacing the bumper fix my turn signal as well or would I have to buy another? Is there another solution to replacing the bumper? Would a GSR bumper fit? any advice would be appreciated.
Please don't listen to this guy. ANY bumper from ANY '94-'97 Integra sedan/coupe, GSR, LS, Type R whatever are all identical. If you don't believe me, go look up the part numbers yourself. oemacuraparts.com. '98-'01 will also work but will look different because of the facelift in '98. Also, no you most likely do not need to replace the bumper or turn signal. Just jack the car up and get underneath of it and take a look for yourself. The lower portion looks like it just needs to be reattached. Same with the turn signal. Just take a look at it and see, it's pretty straight forward. If you do see broken plastic on the bumper, then go ahead and replace the part (upper/lower bumper) that's broken.
Well it all depends. I would always go with OEM bumpers. There's a quality difference between OEM Honda bumpers and aftermarket replacement parts. The easiest way to tell is only OEM bumpers have the word "Integra" on the front. Otherwise it's aftermarket. The other thing to consider is whether or not you have to paint the new bumper you're buying because that also costs money. Which hooks are broken? Is it the top or bottom bumper?
When I had to cut out the signal light bracket for my intercooler I didn't have a a bracket to screw my signal light to anymore but I just ghetto rigged it literally screwed in a big screw slightly in the bottom and used it to anchor in the lip of the opening for the signal light. It still holds fine even under boost lol hard to picture what im saying but you can fix the signal light even if it doesn't have the metal bracket attached to the bumper. But if you wanna be gangster put a CDM front bumper on hahaha!! it cost as much a a used Integra itself lol but no just put any integra bumper on .
Ronpoe415
Jan 23, 2019 10:25 AM
8o8da9speed
Jul 5, 2004 03:43 PM
