Piston Slap ? Collapsed lifter? Worn out camshaft lobe?
Old Sep 14, 2018 | 02:25 PM
Carlos Arispe's Avatar
Default Piston Slap ? Collapsed lifter? Worn out camshaft lobe?
Hi folks, my 99 civic (NON VTEC, where i live civics didnt come with vtec) has 167 000 miles, and it has been having a loud ticking or knock sound when cold startups, Then when it gets to full operating temperature it fully goes away. It doesnt have any loss of power and i already adjusted the valve lashes. Do you hace any clues? is piston slap/collapsed lifter common problems on these civics ? Also if my civic doesnt have hydraulic lifter is a collapsed lifter posible?
Old Sep 14, 2018 | 02:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Piston Slap ? Collapsed lifter? Worn out camshaft lobe?
These cars do not have lifters. This is a direct lobe to rocker arm setup.
Piston slap is possible as the piston become out of round.
As long as the sound is going away with engine coming to temp, I wouldn't worry about it. Once it no longer goes away with engine temp, then look into rebuilding or new motor etc.
Old Sep 14, 2018 | 04:52 PM
Chance EG's Avatar
A video of the noise would help. Could be a few different things.
If the engine feels healthy and it goes away once it's warmed up, it's probably not super critical/immediate.
Old Sep 14, 2018 | 06:29 PM
Thanks for the replys guys, well i didnt have a clue that these didnt have lifters haha, im sorry for that, so basically the problem may be wornout lobes and piston slap? , what about some loose rocker arm?
¿What can i check when i remove the valve cover off?
Here a video i uploaded of the sound it does when cold :
Old Sep 14, 2018 | 07:00 PM
Chance EG's Avatar
Thanks for the video.
Noise does sound like it's coming from the block. Most likely it's ring tolerances/piston slap, which is going away when the rings expand at operating temperature.
I wouldn't worry about it unless you start losing power, or notice that you're burning a lot of oil. Just keep an eye on it.
pityocamptes
Mar 10, 2011 11:14 AM
Boost2NA
Dec 4, 2010 12:20 PM
zombo
May 10, 2010 04:19 PM
mitrellim
Sep 18, 2007 04:23 PM
