Help! In need of window track rubber.
I have a 95 ex that has an annoying issue with the window coming off track. After fixing it about 3 times, I found out the cause: the rubber inside the window track on the side closest to the rear of the car has a tear in it about 2 inches below the top of window ledge. So, if I roll my window all the way up, once it comes back down it smashes that part down and then pops off track. I am looking for information as to what this is even called and where a reputable place to order it from for would be. Also, any info on removing this piece or if it is even possible to remove would be great. Winter isa coming and I don't want to be caught with my window down!
Almost need an interpreter for Tony's answers.....
OEM Honda could be a discontinued part. You can look through the OEM Honda online parts sites to see and get a part number. If it's discontinued then you will be forced to pull it from a salvage yard and go used part.
Almost, definitely need a translator.
Nighthawk7thGen
Honda Civic (2001 - 2005)
Sep 17, 2008 08:03 AM
Markb16a
24
Oct 8, 2007 08:31 PM
EnKidu
Oct 12, 2004 07:08 PM
samson1
Jun 21, 2004 08:35 AM
