Will PS rack seals be damaged by running car w/PS belt removed?
Old Sep 13, 2018 | 08:31 AM
Jon Petersen's Avatar
Default Will PS rack seals be damaged by running car w/PS belt removed?
Hi there. Last summer I replaced my steering rack with a remanufactured one because it leaked a ton. Now, I have a squeaky belt, so I took off the belt from the power steering pump to see if it was the culprit. It got me thinking whether I could cause any damage to the seals. I can see both sides: first, no, because there's still fluid in the system, it just isn't flowing. But yes, because fluid flow keeps seals good.
The thing is, I don't really care for the PS enough to want to keep it. It's really not hard to turn the wheel except when I'm not moving, and with it disconnected my engine is more efficient anyway. Plus, if I deleted the power steering system entirely, I could have more room for a turbo, which I want to do in the distant future.
Really I guess the question is: "is there a reason to switch from a power steering rack to a manual steering rack, it can I just leave the PS rack in with everything disconnected because I really really really don't want to swap steering racks again.
Thanks for your thoughts.
Last edited by Jon Petersen; Sep 13, 2018 at 08:34 AM. Reason: I misspelled a word in the title, how embarrassing.
Old Sep 13, 2018 | 09:14 AM
1999 Civic Si's Avatar
Default Re: Will PS rack seals be damaged by running car w/PS belt removed?
There shouldn't be any issues, a lot of people do it & really as long as there is still fluid in it you should be fine. I personally switched to a manual rack in my EM1, I don't like having to turn the wheel so hard at low speeds. If you want to keep the p/s rack, you can just buy a loop kit, there are a few versions, some are literally just a tube that loops both connections and others have a loop & a reservoir on it so you can keep the fluid topped off.
Old Sep 13, 2018 | 09:20 AM
Thanks. Why is a manual rack easier to turn at low speeds? And what the heck is a loop kit?
Old Sep 13, 2018 | 11:00 AM
The manual rack is/was easier because it has a different gearing/tooth count on the rack internals, basically it takes more turns lock to lock compared to a p/s rack. For daily/spirited driving I never noticed a difference on turning speeds.
I am at work so I can't really get any photos, but if you google "honda p/s loop kit" you will see what I am talking about. It is literally exactly what it sounds like, you are bypassing the pump and looping the high pressure and suction lines together at the steering rack. Same concept as removing the p/s belt, you just remove the pump & hoses, looks a lot cleaner and frees up space.
Old Sep 13, 2018 | 05:26 PM
mk378's Avatar
If your car has to pass a safety inspection, disconnecting the pump, with or without a "loop kit", may not be legal. A power rack with no power doesn't work as well as a manual one.
Old Sep 13, 2018 | 07:34 PM
Freedo_Civegra's Avatar
The one in my Integra turned great without the belt on. I could turn it lock to lock sitting still on pavement without much trouble at all. Really surprised me.
Old Sep 13, 2018 | 08:00 PM
Fortunately, Utah got rid of safety requirements. For some reason. But whatever, I can drive without lugnuts on if I really wanted to! I won't, but I could. Thanks for the input though, I wouldn't have thought of that.
Old Sep 13, 2018 | 08:01 PM
So I can't just plug the lines on the steering rack? I think I'll just go get some hose from the junkyard and connect it that way if I decide to delete the power steering.
Old Sep 13, 2018 | 08:06 PM
They have to be connected to each other, not plugged, so that the fluid can circulate when you turn the wheels. Plugging the lines will put too much fluid *resistance* in the system when steering and cause the car to be really hard to steer.
Old Sep 13, 2018 | 08:07 PM
That makes sense. Thanks man.
92LXcb7
Mar 14, 2012 08:57 AM
doubleoazn03
Apr 17, 2008 09:52 AM
Ultraspeed DC2
Jun 25, 2006 04:30 PM
PokePride
Apr 17, 2005 02:12 PM
yoshi234
Jan 7, 2002 09:19 PM
