Best Method for Restoring Factory Hardware
Old Sep 12, 2018 | 03:26 PM
Nave43's Avatar
Default Best Method for Restoring Factory Hardware
Everyone hates rusty fasteners and brackets. Lets make them go away, whats the best way to preserve the head of a bolt?
I have had great luck removing the rust from rusty Honda hardware using distilled white vinegar soaks. Usually 24-48 hours will eat off the bulk.
Follow that up with a soak in "Metal Rescue" which really eats off anything left. Could go straight to the MR but vinegar is much cheaper.
The problem now is the flash rust.
I would like to get a parts tumbler for a 3rd step and im relatively sure they would be rust free and solve the flash rusting issue from the rinse.
Now i have rust free bolts with 0 protection. What do you fine people prefer as a solution, what will last. do I
  • Soak them in a protective oil ( Ballistol/gun oil? )
  • Zinc electroplate ( Very soft )
  • Dip the heads in POR15 or a similar encapsulator ( Hard could be brittle? )
  • Heat quench the hardware with a high carbon motor oil
  • Paint them (Cheap and works but chips)
  • Black oxide coating
Old Oct 22, 2018 | 10:56 AM
Tom B's Avatar
Default Re: Best Method for Restoring Factory Hardware
Zinc plating is what Honda use.
hatchyboy89
Aug 18, 2011 10:38 AM
lsturboswap
56
Apr 23, 2007 08:32 AM
killerpenguin21
Aug 5, 2006 11:42 PM
legendboy
Sep 3, 2002 07:13 PM
b20a1
Jul 31, 2002 11:42 AM
