Transmission & Drivetrain Gearboxes, Differentials, Clutches
S4C Counter Shaft with LS Ring Gear?
Old Sep 12, 2018 | 08:16 AM
integrawillie's Avatar
Default S4C Counter Shaft with LS Ring Gear?
I'm 99% sure I have to swap the entire final drive ring gear/countershaft, but I just wanted to double check. I'm using an S4C trans with Mfactory diff. I need to stretch the gearing out just a touch and have a good LS trans laying around. Was going to rob the ring gear and countershaft from the LS. I see the part numbers are in fact different between the two, just wanted to make sure that I'm not able to swap my ring gear in and leave the countershaft untouched.
Old Sep 12, 2018 | 09:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: S4C Counter Shaft with LS Ring Gear?
No you cannot swap the ring gear only... the counter shaft is a matching set.
Old Sep 21, 2018 | 01:34 PM
Aquafina's Avatar
Even if the part numbers were the same you would need to swap the complete matching set.
Roy0207
Nov 10, 2017 04:20 PM
blue ej8
Apr 26, 2013 07:47 AM
metalhelixx
Aug 4, 2012 04:47 PM
dcraige
Apr 2, 2010 06:32 PM
