Timing Belt parts
Getting a list of parts ready to order for my timing belt. Just making sure I snagged everything. Have a 01 GS.
Also have a new thermostat, thermostat housing, skunk2 rad hoses, and skunk2 radiator in the mail already.
water pump 19200-P75-003
cam front seal 91203-PG6-003
timing belt 14400-P7J-004
timing belt tensioner 14510-P30-003
timing belt tensioner spring 14516-PR4-A00
crankshaft seal 91212-PR4-A01
valve cover gasket 12030-PR4-000
spark plug gasket 12342-PT2-000
valve cover washer 90442-PR3-000
Power Steering Belt 4PK-920
Alternator Belt 4PK-790
Air Conditioning Belt 4PK-870
My local dealer could order them fairly quickly. Hondpartsnow was a lot cheaper though, like $200 less. I caved and just had a local shop do the belt as I was short on time.
Just a question, are you supposed to replace them or did you have them mess up on you ? I have done multiple timing belt water pump replacements on my cars, 200k + and never replaced them and haven't run into any issues yet, not doubting you just curious
I had to replace 2 of them the last time on a B18B1 due to them breaking at the bolt head. Luckily, I was able to remove it with some vise grip pliers.
yeah note bolts 21 and 22 are different lengths (thanks honda).
mixed them up and broke one off.
couldnt get it out but a liberal amount of toyota bond on the pump mating surface
took care of bidness. reviews on amazon and ebay call it the best.
safety1910
15
May 30, 2012 06:39 AM
doostin
Feb 1, 2009 04:45 PM
