Honda Accord V6 won't rev past 5k rpm
Hi allSo I have a 07 Accord EX-l V6 at 118k miles. It runs great, everything is maintained well and it's as smooth as butter. Except when you hit 5200ish rpm. This started happening once I did a timing belt change along with water pump and pulleys and all went well. I was meticulous with the change and made sure everything was in time at least a million times. After that I did a few maintenance items:
- Trans fluid change
- Power Steering fluid change
- Coolant change
- Air filter change
At first I thought it was the trans slipping but this also happens when I put her in neutral and rev. I also checked to see if the coils or plugs were but all of them were firing as normal too. I have read that it could be a problem with VTEC is this a possible cause?
Thanks for the help and I'll update the post if I remember anything else.
Edit 1: First startup after timing belt change was smooth and normal so I assume everything thing went as planned.
plus1
Oct 27, 2004 11:07 AM
