D16z6 solid mounts
Old Sep 6, 2018 | 08:03 PM
tercelrcr's Avatar
Default D16z6 solid mounts
Hey guys, anyone know if there is a company that makes solid motor mounts for a d16z6? Someone told me b series would work but i dont think so.
Old Sep 8, 2018 | 09:51 AM
tercelrcr's Avatar
Default Re: D16z6 solid mounts
Anyone???
Old Sep 8, 2018 | 08:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
In some cases, "B" series mounts are SIMILAR to "D" series mounts. Coupled with the proper supporting components, they will work in your Civic. The real question is WHY do you want solid mounts ??? There is really no good reason to have them.
Old Sep 9, 2018 | 10:05 AM
Nave43's Avatar
Remove stock Z6 mounts, burn out the old rubber. Now "cast" yourself a new solid poly mount reusing the central tube and some liquid polyurethane. Or even a tube of poly window sealant (3M Window adhesive) would do if you want to do it ghetto.
Going to Solid Aluminum mounts is going to be more costly and really have no place on a street car.
DIY VIDYA
Old Sep 11, 2018 | 06:49 AM
tercelrcr's Avatar
Ok thank you guys so much for the help. I decided im just going to try stock mounts since its only the rear mount on the firewall that needs replaced.... on that note, anything i shiuld be aware of when replacing it?
xwhitchx
15
Jun 19, 2009 08:30 PM
eg_21
Jun 8, 2009 07:54 PM
wpgcivic
15
Dec 8, 2005 03:51 PM
ecl-ricochet
Jun 17, 2005 07:26 AM
Pioneer162
Oct 6, 2004 09:33 AM
