high/low beams not working
Old Sep 6, 2018 | 04:45 PM
K-G's Avatar
K-G
Default high/low beams not working
What’s up guys
so today I decided to put my hids back in finally after swapping (same motor in) so I could drive at night.
However neither of my lights work besides parking. Everything worked before fine and my hids are good. I had them tested. Fuses are okay and ground is good.
Not sure what to check next, any ideas ?
Old Sep 6, 2018 | 05:00 PM
mk378's Avatar
Default Re: high/low beams not working
Jump the ballast to a battery to confirm this "my HIDs are good" theory.
Measure for voltage going into the ballast. Do not attempt to measure on the wire between the ballast and the bulb.
If the stock bulb plugs are still in the car, plug in a stock bulb and see if it lights up. (You don't have to put the bulb in the housing to do that).
Turbo1983's Avatar
Did u check your grounds? Are the ballast still good?
Old Sep 7, 2018 | 01:41 AM
K-G's Avatar
K-G
My hids were tested at Tristate. They both work and I also took my ballast from my other car to check that and it still didn’t work.
My ground is good. Is there more than one headlight ground?
Old Sep 7, 2018 | 01:44 AM
K-G's Avatar
K-G
I Will have my father help me with measuring voltage as I’m not sure how to do that. I don’t know Much about electrical.
Im 110% positive the bulbs and ballast are good. The car sat for two years prior to dropping the motor.
Is there any other fuses besides the ones under the dash for headlights ?
Old Sep 7, 2018 | 06:07 PM
Turbo1983's Avatar
Just a question your hid kit does hook into the original headlight socket correct? Try to put a stock light bulb in original socket to see if it works. If it does work then you can look at the ballast or the hid bulb.and the question on more grounds an fuses ( grounds idk ) ( fuses- I only know of under dash).
Old Sep 7, 2018 | 06:09 PM
Turbo1983's Avatar
Mk is pointing in right direction.
91_Project
Mar 25, 2014 05:56 PM
civicpark81
Lighting
May 14, 2012 08:38 AM
xcracer
Lighting
Mar 16, 2011 02:59 AM
mrbassman001
Jan 7, 2011 10:22 AM
Shortyluvsu2808
Lighting
Oct 21, 2009 12:11 PM
