ECU Help
Old Sep 6, 2018 | 05:23 AM
SCMFOX's Avatar
Default ECU Help
I have a 97 ej9 that I’m swapping a 00 GSR engine, however the ECU connectors are different how do I go from a PX3 ecu with 2 connectors, ( Obd2a) to an p72 Obd2b ECU with 3 connectors?
thank you in advance
Old Sep 6, 2018 | 01:25 PM
Feriohhh's Avatar
5 Year Member
Default Re: ECU Help
Just use an OBD2a P73, which should plug right into your harness. They're widely available and inexpensive. Also, Both OBD2a and OBD2b use three connectors.
Old Sep 6, 2018 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
OP, are you in the US ???
Old Sep 11, 2018 | 07:04 AM
SCMFOX's Avatar
Not currently in the US
Old Sep 11, 2018 | 01:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
OP, you need a GSR ECU from an appropriate model vehicle that has the same type of ECU plugs as your chassis. I don't recognize a "PX3" ECU type, so I assume this is from another market outside of the US. Some pictures of your current ECU plugs might be helpful... let's see what you have.
Old Sep 13, 2018 | 12:05 PM
SCMFOX's Avatar
From my 1997 honda civic ej9
only two ports
what needs to go into my civic. P72 ECU
Old Sep 13, 2018 | 07:29 PM
Freedo_Civegra's Avatar
Thath a thtumper
Old Sep 14, 2018 | 12:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Oh boy... your ECU has TWO (The "A" and "C" plugs) of the three OBD-1 style plugs normally found on a '92-95 USDM ECU... in a 1997 EDM chassis !!! The smaller (B) plug you are missing has a LOT of important wiring in it here in the US... like all of the distributor sensor wires. Typically, you will find 10-12 wires in that plug. I don't know that I have ever seen a plug and play conversion of some type that connects the engine harness to the ECU that you have. This makes me wonder if the basic mechanical function of your car's original engine is drastically different from the GSR's... like carburated and a TDC sensor only in the distributor.
Maybe the thing to do would be to get a USDM OBD-2A engine harness that matches your green crossover plug and build from that. Take a close up picture of the chassis side of the green crossover plug seen on the left side of your second photo above and post it... and a good shot of the junction where the engine and chassis harness connect in the engine bay OPPOSITE of the side where the engine harness comes through the firewall and terminates at the ECU.
Old Sep 14, 2018 | 12:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Was your car automatic before you did your swap ???
Old Oct 7, 2018 | 03:51 AM
SCMFOX's Avatar
My vehicle wasnt at anytime auto
Sohc Driver
Nov 18, 2003 05:11 PM
