Brake light
Old Sep 5, 2018 | 12:33 PM
Drmetz's Avatar
Default Brake light
Brakes lights stopped working, as well as cruis control and transmission stuck in park. I have changed all fuses and replaced the brake switch, but still does not work. This is a 2001 civic
Old Sep 5, 2018 | 01:59 PM
mk378's Avatar
Default Re: Brake light
This forum is for 1992-2000 models, but I think on the 2001 the fuse in question is also in the box under the hood near the battery.
You would want to check the two big wires on the pedal switch, one should have battery voltage all the time (from the fuse box) and the other one only when the pedal is pressed (that wire goes to the lights).
DerekHollister
Apr 4, 2016 02:06 AM
99civic4dr
May 25, 2012 02:04 PM
NYVALL
15
Apr 9, 2012 06:22 PM
Type-Spaz
Oct 2, 2011 04:44 PM
keepitngga1
Jul 18, 2008 10:26 PM
