P06 ecu Fuel Priming
Old Aug 30, 2018 | 10:46 AM
dlx111's Avatar
Default P06 ecu Fuel Priming
So I've been having fuel pump priming issues with my ecu for a while now, I just recently replaced all the resistors with the pack from Xenocron hoping that would solve it. It seemed to improve a little but I'm still getting intermittent issues with the pump not priming. I have another P06 that has the original resistors in it (the board looks alot cleaner though) and it primes every time. I emailed Xenocron for some help and they said C14 is one of the main components for fuel priming but it could be other issues. Just curious if anyone else has had success with just changing resistors or if theres another component I can look at/replace?
Old Aug 31, 2018 | 12:27 PM
Relic1's Avatar
Default Re: P06 ecu Fuel Priming
resistors do not stop the ECU from running the pump... capacitors do. Make sure you replaced the right things.
Also, you can make thing worse if you didn't do a clean/good job replacing them.
Galan
May 21, 2011 03:55 AM
no_rice_please
Engine Management and Tuning
Oct 12, 2009 09:36 PM
boosted k20
Feb 9, 2009 09:15 AM
b16a1sirhb
Apr 9, 2003 11:50 PM
