Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Oil leak from spark plug?
Old Aug 29, 2018 | 03:31 PM
Jesse M's Avatar
Default Oil leak from spark plug?
I just bought a 04 civic 4door sedan and I noticed that there's oil leaking from underneath the plastic spark plug housing.. Car seems to be running fine but it looks like it's been going on for awhile from all the built up oil dripping below.. Is this an easy fix, should I be worried? Should I stop driving it till I can fix it?
Old Aug 30, 2018 | 08:38 AM
thisguyaves's Avatar
Default Re: Oil leak from spark plug?
Pics?
Sounds like Valve cover gasket ant the O-ring gaskets that go around the spark plug tubes. 30 min fix. It'll be ok, nothing major to worry about unless the leak is really bad, but it's a cheap and quick repair, so no reason to put it off.
Old Sep 13, 2018 | 12:02 PM
Buster _'s Avatar
I had the same issue I replaced the valve cover gasket and that fixed the problem but when yah take the cover off look for spots that might be chipped or worn to make that spot leak
Old Sep 13, 2018 | 12:22 PM
Jesse M's Avatar
i went ahead and changed the valve cover gasket even though it looked pretty new, whoever has the car before me skimped and didn't change the tube seals, instead they caked the old ones with rtv silicone which threw me through a loop scraping it all off and then figuring out I could just just polio em out.. I might have to pop it open again to put some silicon around the corners like I've seen a few people do on you tube.. I wanted to but I didn't.. Any thoughts on that? For now I'll just Keep spot checking for leaks..
Old Sep 13, 2018 | 01:42 PM
Buster _'s Avatar
If it’s not leaking ur fine but it doesn’t hurt to keep checking if the problem comes up again get another gasket and use jb weld high temp rtv under the gasket I think that would be the best bet
Acura_DreamiN
Oct 26, 2010 07:23 PM
lgharis
May 23, 2007 06:10 PM
loup05
Jan 28, 2006 05:30 PM
civicxspower
Jun 5, 2005 04:12 PM
combustion
15
Apr 11, 2005 02:53 PM
