01 GS suspension rebuild, go ITR suspenion?
Old Aug 29, 2018 | 06:59 AM
chappys4life's Avatar
Default 01 GS suspension rebuild, go ITR suspenion?
I picked up a 01 GS 5 speed over the weekend with 130k. I plan on doing some hpde maybe autocross events so plan on replacing bushings and brakes. To make life easier I am looking at buying new lca's, front uca, tie rods, and koni yellows. I see hardrace supplies front lca's but the only lowers they sell are ITR which require ITR rear shocks. I am totally fine with that as I am buying new shocks but is there any disadvantages like abs lines or any gotchas when making the conversion?
Old Aug 29, 2018 | 09:12 AM
aw614's Avatar
10 Year Member
Loved
Default Re: 01 GS suspension rebuild, go ITR suspenion?
it forces you in a higher class for autocross if that matters for you. Other than that I like the ITR suspension with a good set of shocks that aren't worn out Its a great suspension, car still looks stock, etc. Make sure you get a larger sway bar too.
The ABS sensor lines, one of the bolt holes doesnt match on the LS/GSR rear with the ITR LCAs. I just zipped tied it on and its holding up.
Old Aug 29, 2018 | 09:28 AM
I think im screwed in autox since I have a cold air & front strut bar that was on it when I bought it.
Old Aug 29, 2018 | 02:18 PM
MotorMouth93's Avatar
10 Year Member
It would probably be cheaper to buy a bushing kit and replace just the bushings instead of the whole arms. The Hardrace kit is about $300 for everything and a shop should be able to press them in for you for not too much money.
Old Aug 29, 2018 | 02:48 PM
it would butbthe extra hassle is not worth it. I have had mixed results doing that. It’s easier to get a whole arm ready to go.
Old Sep 8, 2018 | 08:34 AM
Saul_Good's Avatar
Seems like you want a mild suspension performance bump. Koni Yellow/Bilstein B6 shocks + some eibach prokit (1.3/1.3in drop) would give you that modern performance bump you want. That combo will still be streetable from a comfort and getting over/around daily road conditions too.
mrdeadman
Mar 20, 2006 03:56 PM
hazard_one
Suspension & Brakes
Apr 28, 2005 05:44 PM
cedete
Nov 8, 2004 07:18 PM
DI9ITAL
Feb 11, 2004 11:50 AM
keys
May 17, 2002 06:07 AM
