2006 Odyssey AC warm at Idle...sometimes
I have an '06 Odyssey and the AC is warm at idle...sometimes.
I'm in South Texas and the outside temps are high right now (95+). AC blows ~85 deg at startup and drops to ~55-65 (depending on the vent) while driving. Once I stop, back up into the 80's. Caveat, If I've been driving for a while and the inside temp has cooled off it will hover around 65 deg at idle.
What I've checked:
Both fans are on
Compressor stays on
Had the AC vacuumed and recharged a couple months ago due to leaking Schrader valves (valves were replaced)
AC pressure (warmed up and ambient temp 95+ deg)= 190 High side/40 low side.
Thanks for the help
What I've checked:
Both fans are on
Compressor stays on
Thanks for the help
Civic Racer X 7
Aug 8, 2007 05:15 PM
