So my EF harness is messed up. The harness side of my distributor plug does not have the plug housing so I have no idea where the color wires connect to the distributor plug.
*The harness side has 5 wires colored: Green/Yellow, Black/Brown, Red, Red, Yellow/black.
*The distributor plug has 5 connections with the colors: White, Peach, Yellow/green, Blue, and Blue/yellow.
Every wiring diagram I look at does not have the same colors I do.
Can someone who knows where they go just mach the colors for me please!!
THANK YOU!!
Harness side of the plug.
Distributor Plug
Distributor Plug.
I need to connect those 5 wires into this housing plug to plug into the distributor side.
Below is the wiring diagram (engine harness side) from my 90 DX Sedan before I did the MPFI swap, so this should be the same for you...other than wire colors. It looks like someone modified your harness, because I don't think those colors are stock. You may have to probe the wires to find out where they go. In my diagram below, C101 is the 14-pin plug at the passenger's shock tower, and C122 is the 14-pin plug at the driver's shock tower.
