93' Del Sol ESi EH6/D16Z6/S24A Transmission
Old Aug 26, 2018 | 08:59 AM
badpaw's Avatar
Default 93' Del Sol ESi EH6/D16Z6/S24A Transmission
I have a hole in my trans case and Im trying to purchase a used or rebuilt transmission. The current transmission was previously rebuilt and the upper ID tag was washed off in the solvent bath. There is a small P24-1 stamped next to the oil drain plug
I am seeing 17 variations of the S24A transmission produced from 92' through 2003'
Apparently they all bolt up, but each of the 17 variants is different.
The Del Sol chasis was manufactured in November 92 (93') type EH6 2 door Del Sol Si (ESi) The engine stamp indicates the factory D16Z6 engine is installed.
The S24A is showing 17 models, is there a cross reference anywhere to see which transmission came factory in the 93' ESi? Thank you for your help!
S24A variations: A24A/A2YA/A4RA/B46A/B4RA/B7ZA/BDRA/BMXA/M24A/M4RA/M4TA/MCVA/MDLA/MDMA/MRVA/S4RA/SLXA
mmunozem1
Jan 26, 2014 02:56 PM
Varao
Aug 18, 2005 02:37 PM
pyro_freak8
Jan 3, 2004 08:54 PM
