K24/k20 rsx build
Old Aug 26, 2018 | 07:42 AM
Arlen2727's Avatar
Default K24/k20 rsx build
Okay so I blew my motor the other day in my type s and figured might as well go k24. So I got a k24a4 and still have my blown k20a2 and was wondering what all I’ll need for this swap. Had planned on doing it anyways but was rushed into it when my motor blew any help would be great.
Old Aug 26, 2018 | 10:44 AM
thisguyaves's Avatar
Default Re: K24/k20 rsx build
Search, search, search! Others have asked the same thing!
First and foremost, you will need a tune-able ECU. The K24 motor mounts are different because it's taller, so you'll also need the passenger side mount from a K24 equipped CRV.
The A4 has far less compression as well, be prepared to gain TQ but lose HP.
Old Sep 16, 2018 | 06:00 PM
Arlen2727's Avatar
Okay so am shopping for pistons currently I’ve heard that wiseco 12.5.1 would be good. I’ve found some but they say +5cc and I’m not too sure what that means and what difference it makes. This is my first time really building a motor all I’ve done in past it basic bolt on stuff
Old Sep 16, 2018 | 08:59 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
That is the dome volume of the piston. Using the Zealworks calculator, a standard sized piston (87mm) with a 5cc dome volume in a stock height K24A4 block and an unmodified K20A2 cylinder head... I get a compression ratio of 12.66:1.
Old Sep 17, 2018 | 06:26 AM
Just a heads up, weisco is great, but they're not the only option out there, and certainly not the most affordable... Supertech makes a comparable piston, as does other big names like Brian Crower, Skunk 2, etc.
Old Sep 17, 2018 | 06:54 PM
Arlen2727's Avatar
Okay cool thanks for clearing up the whole 5cc thing kind of thought that’s what it was just wanted to be sure. Also yeah I’ve checked into super tech and Brian crower was skeptical of skunk 2 I just don’t know many people around me using skunk 2 besides bolt ons but I’ll check them out as well. I plan on just doing high comp pistons and some good rods and put it all together and ride it like that for now since I was rushed into this and tight on funds, until I get some more funds... then do some head work cams valvesprings etc looking for 250-260 hp in the end. Just a fun dailyable rsx
Old Sep 17, 2018 | 06:55 PM
Arlen2727's Avatar
So any suggestions welcome I think I got a pretty good plan for the whole thing but any suggestions would help or what you guys have done. I’ve done a lot of research. So got a pretty good idea of a plan
bambam
13
Aug 23, 2019 08:03 AM
petersayarath
Aug 25, 2007 09:04 AM
PhilTran.o7
Nov 16, 2006 09:52 AM
ian04rsx
Aug 2, 2005 08:08 AM
Maddox
Sep 6, 2004 05:48 PM
