Hondata
Old Nov 13, 2002 | 09:11 AM
smslude's Avatar
Default Hondata
I was just wondering what exactly the hondata is used for and how much it costs.
Old Nov 13, 2002 | 09:13 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Hondata (smslude)
standalone fuel managment
their prices on on the site http://www.hondata.com
Old Nov 13, 2002 | 09:14 AM
satan_srv's Avatar
Default Re: Hondata (Boosted97Lude)
Old Nov 13, 2002 | 09:18 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Hondata (satan_srv)
your such a post ***** satan
[Modified by Boosted97Lude, 1:21 PM 11/13/2002]
Old Nov 13, 2002 | 09:37 AM
satan_srv's Avatar
your such a post ***** Boosted97Lude
[Modified by Satan_SRV, 1:21 PM 11/13/2002]
Old Nov 13, 2002 | 09:58 AM
Boostless97Lude
Guest
Posts: n/a
isn't it obvious, you've been here 2 day longer than me, and i've got more posts
Old Nov 13, 2002 | 11:26 AM
lildrgn2.0's Avatar
New User
you also have to remember that you cant use a hondata with our ECU. You will have to buy a conversion harness and swap out the ecu (probably with a GSR ECU) so you can open the secondaries.
Hondata = dyno time = $$$$
Old Nov 13, 2002 | 11:46 AM
BoostedH23a1's Avatar
Default Re: Hondata (Lildrgn)
thats on OBD 2 cars...
Old Nov 13, 2002 | 12:12 PM
ludespeeder's Avatar
Default Re: Hondata
I'd just get a standalone. To me the hondata is just a glorified piggyback. I would run a Tec2 or 3 or get the AEM setup. (don't really care for AEM ECU but a REAL standalone will be much better than a hondata for medium-wild applications)
Old Nov 13, 2002 | 12:16 PM
PrecisionH23a's Avatar
Default Re: Hondata (ludespeeder)
Do you have any experience dyno tuning the AEM? If aem sends you a base program that actually allows the car to crank, then you are looking at a good 6-8 hours to tune the car. Sure there are better systems out there then the hondata, but you have to know what you want from your car. For a daily driver wanting 450whp then id recommend hondata.
Old Nov 13, 2002 | 12:34 PM
lildrgn2.0's Avatar
New User
Default Re: Hondata (BoostedH23a1)
i didnt think they had a hondata for the Prelude ECU at all..
what is our ECU number anyway?
[Modified by Lildrgn, 9:36 PM 11/13/2002]
Old Nov 13, 2002 | 01:01 PM
Boostless97Lude
Guest
Posts: n/a
i have an OBD2 Prelude, i also have a couple of spare OBDI ECUs, so i've got no problem, but i prefer Hondata over EMS anyday
Old Nov 13, 2002 | 01:12 PM
apexii's Avatar
Our ecu is a P13 model, and Hondata does not modify it yet. The obd2 preludes are still using p13 ecus, but they have a different adapter. We can use the p72(gsr) or p28(civic ex). The p28 does not have secondary runner support, but I am not going to need it anyway.
For the money, you cannot beat hondata.
Old Nov 13, 2002 | 01:31 PM
RAB's Avatar
RAB
I think I heard that on the Fast and Fagulous
Old Nov 13, 2002 | 06:48 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Hondata (RY8127)
i'm still trying to fiugre out how "Dom" knew the car had standalone just by looking under the hood
Old Nov 13, 2002 | 07:03 PM
DirtyLude's Avatar
GM sensors? Custom crank trigger? Custom wiring harness? Direct fire igintion? Do DSM's come with stock direct fire? Could be anything like that.
Old Nov 13, 2002 | 07:12 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Hondata (DirtyLude)
DSM's use DIS ignition, and are MASS flow, so they wouldn't have a GM sensor...
but just by glancing under the hood??? amybe if the damn standalone was mounted under the hood
Old Nov 13, 2002 | 07:51 PM
smslude's Avatar
Hey man get it right its
"The Rice and Ridiculus"
Old Nov 13, 2002 | 09:19 PM
RAB's Avatar
RAB
Hahaha better.
Old Nov 14, 2002 | 04:45 AM
DirtyLude's Avatar
The point is most standalones DO use GM sensors and if it was running a standalone, it would be converted to MAP with seperately taped GM coolant and air temp sensors.
Old Nov 14, 2002 | 06:42 AM
Jason kiDD's Avatar
Or maybe it was just the big ole laptop in the passenger seat..?
Old Nov 14, 2002 | 07:00 AM
DirtyLude's Avatar
Default Re: Hondata (Jason kiDD)
Watch out, or you'll get a:
Old Nov 15, 2002 | 10:10 AM
Nosser's Avatar
Has anyone used the P72/Hondata combo in an N/A 5th gen? Apperently their new setup for the K20 is very impressive, especially in terms of torque. I am pretty interested to see what they could do on an N/A H22. Anybody have any info?
Old Nov 15, 2002 | 10:19 AM
baddboy's Avatar
Default Re: Hondata (Nosser)
how much did you guys pay for your gs-r ECU's
Old Nov 15, 2002 | 10:24 AM
I agree that the AEM is a POS, they just released a new upgrade for it and thguy here that has one is STILL tuning it. It's been like over a month since he had it put in, dyno'd it to get it runnin, and then has just been drivin around tryin to tune it out.
Personally I have seen with my own eyes a car make 20 more HP to the wheels by changing from a FAST setup to a Tec2 setup. Plus the TEC has an autotune feature for WOT and for cruisin. Plus you can have 3-4 maps on it without having to burn ROM's and keep changing chips out. I am going with a tec setup once I get my tranny situation fixed. Best damned standalone I've ever used. PERIOD.
