Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
p0141
Old Aug 24, 2018 | 08:14 PM
jimdamico's Avatar
Default p0141
So today i lengthened the o2 downstream sensor wires and soldered them instead of butt connect heat shrink and then taped them cleared the code and took it for a ride. check engine light stayed off cycled the key 4 or five times went for another ride no check engine went inside took a shower thinking im going to smog it now when i got back in started it po141 again how can i smog it if i cant keep erasing it every couple of hours the im moniters keep resetting every time i shut the light off HELP
Old Aug 25, 2018 | 06:27 AM
thisguyaves's Avatar
Default Re: p0141
Your sensor could just be bad, or the wires may not have been soldered to the correct wires.
Old Apr 10, 2019 | 03:10 PM
Dj Dh's Avatar
Default Re: p0141
ok here we go.... it's been two years without a cat, I'm using a spark plug kit with the O2 sensor, one day started raining check engine light came on for p0141, I'm thinking its O2 sensor, and I check the Ohms on it, it was bad so I changed it same thing. I checked the fuse number 4 and good but I still changed it, still samething. Voltage it is good on the o2 side ... WHAT CAN IT BE ... it's bank 2 ..... I JUST WANT THE CEL OFF
Old Apr 12, 2019 | 09:58 AM
NDNV's Avatar
Default Re: p0141
Use an OEM Honda O2 sensor. Denso is the make.
LOW_ONBILLETS
Jun 28, 2010 03:27 PM
thanh4o8
Sep 21, 2009 11:47 PM
incurable
Jan 1, 2007 07:31 PM
mr devious illusions
Jan 26, 2006 11:47 PM
