1982 Prelude Block Coolant drain plug location?
Old Aug 23, 2018 | 08:29 PM
prelude_girl's Avatar
Default 1982 Prelude Block Coolant drain plug location?
Hi all,
Long time since I've had to post; my little '82 just keeps on running so well I have not needed to do so.
However, I've got a simple question for which I have not been able to find an answer. Where are the plugs on the block to drain the coolant on my 1982 Prelude 1.8L engine? I found two bolts that enter the block between the oil filter and the oil pan rail that don't seem to serve any other purpose. Are these the drain plugs?
Thanks
Old Aug 29, 2018 | 08:31 PM
Default Re: 1982 Prelude Block Coolant drain plug location? EK1
Right. So I was able to find the mysterious block coolant drain plug for my engine. It took buying an OEM service manual but I did find it.
The drain is between two freeze plugs below cylinders 1 and 2 (1 being at the end opposite the transmission). On mine with AC, it is under/behind the bracket for the AC compressor.
Note that there are also two more bolt/plugs under the oil filter. I was able to determine from exploded diagrams at estore.honda.com that these are for a remote oil cooler used on Civics.
I hope people find this useful.
Drain plug circled
Drain plug circled
From the manual
JVH
Honda Fit
Apr 1, 2011 12:41 PM
usdmftw
Nov 29, 2010 05:29 PM
redboost10
Jan 13, 2007 12:46 PM
jefe
Aug 10, 2004 07:07 PM
