Idle Problem
Recently acquired a 1997 Ex Coupe with a D16y7 non vtec . It has a Vtec ecu in it as well. My question is: what could be the problem if the car idles well over 4K when clutch is engaged or in neutral. Is it the vtec ecu, iacv, tps etc etc?? Any help would be greatly appreciated!
It is drive able. It does have a check engine light on. Stock as far as I know. Not sure what codes will be pulled I will have go check. And I’m not sure if it’s been converted or not. I don’t have a lot of info on the car as I got it less than 24 hours ago.
maybe so, but the stored codes should indicate that. if there's no TPS code, it'd be a wasted effort to check.
