Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
remove crankshaft from 2006 Accord without removing engine?
Old Aug 18, 2018 | 04:08 PM
gducatte's Avatar
Default remove crankshaft from 2006 Accord without removing engine?
Hello, I am getting ready to start a rebuild of my 2006 Accord 4 cyl. engine. I have heard that it is possible to remove the crankshaft and pistons without removing the engine from the vehicle. I am exploring this possibility because I do not have a lift, hoist or an engine stand. Has anyone done this or know of a video that can help me?
Old Aug 22, 2018 | 09:23 AM
hondamark35's Avatar
Default Re: remove crankshaft from 2006 Accord without removing engine?
pistons: sure pretty much the case for any engine. with the oil pan off to access the rod bolts and the head off to push them out.
crankshaft: the way the K24 goes together it does look possible if you have an automatic (the clutch would be an issue with a manual trans) and you're able to get the flex plate to come out with it. by the time you're able to get it out though you've basically stripped the rest of the engine down to the bare block. you could just lift the block out by hand. they don't weight all that much.
thatsthemove
May 15, 2017 10:57 AM
Bright13
May 27, 2016 01:36 AM
uberEFtuner
Mar 4, 2012 08:27 PM
bmiller17
Mar 18, 2006 09:27 AM
kyosuke714
Dec 12, 2005 05:29 AM
