B18A1 Coolant Pipe
Old Aug 13, 2018 | 07:40 PM
92ChumpCar's Avatar
Default B18A1 Coolant Pipe
We are building a 92 Integra for ChampCar (chumpcar) and have a 1991 B18A1 to install. The coolant pipe going from the water pump to thermostat housing is shot and I cannot find a direct replacement. Are any of the coolant pipes from B18Cn engines compatible? I'm finding they have extra tubes / connections but I will braze or cap those off as long as the pipe fits we should be good?
Appreciate the help!
Old Aug 14, 2018 | 02:45 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: B18A1 Coolant Pipe
HONDA DEALERSHIP, ONLINE OR WALK-IN
Old Aug 14, 2018 | 06:20 AM
92ChumpCar's Avatar
Ah....thanks for the tip. I keep looking at the Acura sites and see the part as discontinued - Honda shows the parts available we need. Again - thanks
Old Aug 21, 2018 | 12:07 PM
92ChumpCar's Avatar
Honda and Acura dealers both tell me this part is discontinued. Specifically part 19505-PR4-A00 for B18A1. Other series B motors appear to have different connections off the side of the pipe and B18C engines the parts are available. Any one use a coolant pipe from a newer Integra B motor on the A1?
Old Aug 22, 2018 | 07:39 PM
egsleepercivic's Avatar
sold out on amazon my bad
Old Aug 22, 2018 | 07:42 PM
found this one
https://parts.coconutpointhonda.com/...iABEgKw_fD_BwE
Old Aug 22, 2018 | 07:43 PM
they maybe discontinued but these dealers might have them sitting on the shelf
https://www.acurapartsdelivered.com/...SABEgKSpfD_BwE
Old Aug 23, 2018 | 03:52 AM
92ChumpCar's Avatar
I called those dealers and they do not have it. They said the website uses some national database that's poorly updated and they are trying to get it changed due to on-line orders coming in for parts they will never have. At least that's what they told me. But it is discontinued from Acura / Honda. I found one along with some other parts I needed from someone else on the forum last night. Appreciate the help though.
Old Aug 23, 2018 | 08:19 PM
ah that sucks man, although it looks like it might be the same pipe as a single cam d series, where you located ? I am in central florida I can keep an eye out at the yard for you next time i go.
also can figure the difference between an b18a1 and a b18b1 ? might be workable
one more thing if its on a shelf at dealer somewhere might be why its in the database check a local dealer and see if they can check the national database and maybe locate it for
good luck !
parsapour
Apr 28, 2018 08:57 PM
shocker911
Mar 6, 2013 02:17 AM
93preludeh22
20
Jul 25, 2008 04:50 AM
superburner2
Jul 25, 2005 07:44 PM
