does the hf wire harness work on the si motor?
Old Nov 13, 2002 | 07:11 AM
pdiddyparsons's Avatar
Default does the hf wire harness work on the si motor?
does the hf haness work on a si
Old Nov 13, 2002 | 07:29 AM
markedOO1's Avatar
Default Re: does the hf wire harness work on the si motor? (lilparsons)
yes...it has some extra plugs for emissions crap....but otherwise, everything should be plug and play.
Old Nov 13, 2002 | 07:31 AM
Hondasaurs's Avatar
Default Re: does the hf wire harness work on the si motor? (marked001)
The HF is also Multiport injection like the Si
Old Nov 13, 2002 | 07:41 AM
elmalouno's Avatar
Default Re: does the hf wire harness work on the si motor? (ZC_CRX)
Ummmm i just asked this yesteday....
heres the link.(i hope)
https://honda-tech.com/zerothread?id=332193
Old Nov 13, 2002 | 08:25 AM
keithv's Avatar
Default Re: does the hf wire harness work on the si motor? (elmalouno)
one thing i know superhatch found out is the 88-89 harnesses are different from the 90-91 harnesses. this was si specific though...
Old Nov 13, 2002 | 08:33 AM
1990hondaHF's Avatar
Default Re: does the hf wire harness work on the si motor? (breaka_1_9)
What about the dizzys from a HF and a SI are they the same?
Old Nov 13, 2002 | 07:19 PM
Default Re: does the hf wire harness work on the si motor? (C5_ALLMOTOR)
yes
Cool. Thanks.
Old Nov 13, 2002 | 07:25 PM
USDM 4G VTEC's Avatar
can u specify what kinda differences he noticed?? thats kinda interesting...
Old Nov 14, 2002 | 04:13 AM
keithv's Avatar
Default Re: does the hf wire harness work on the si motor? (JDM EF9)
here is the post i was talking about:
https://honda-tech.com/zerothread?id=274048
Old Nov 14, 2002 | 04:49 AM
dman it the pics dont work.... cant really see the problem...
Old Nov 14, 2002 | 04:56 AM
Superhatch's Avatar
Ill repost them here when I get home tonight... Basically the plug on the right side of your engine bay that came from the interior harness had 6 wires and my (from a 90 si) engine harness had 8 wires (they goto the injectors).
From what Ive heard...that was from an 88-89 si. But I dont know why it would only have 6 wires. Power and return wire...2 per injector. But with 6 wires..did they just split 2 wires???
Actually I dont know why Ive never checked my std at home. Ill do that tonight also.
-Jake
Old Nov 14, 2002 | 06:18 AM
keithv's Avatar
i guess you'll just have to read the post then...
89loudcrxsi
Apr 7, 2008 11:25 AM
fullraceacura
May 24, 2005 09:49 AM
Serdar
Aug 15, 2003 08:05 PM
91HATCH
23
Oct 15, 2002 05:03 PM
Tbone
Jun 18, 2002 01:34 PM
