Thump/squeak noise while shifting
Old Aug 9, 2018 | 03:11 PM
SubwayH23's Avatar
Default Thump/squeak noise while shifting
94 Si 5spd
It only seems to do it if it rains, even if the car is hot. If it's dry out and the car is hot, it will not do it
It really only seems to happen when immediately pushing the clutch in when upshifting in lower gears, so 1-2 or 2-3. The squeak is there when I push in the clutch and the thump happens when releasing the clutch. If you release it slowly it does not do it. It's obviously something hitting or rubbing but i can't figure out what
I suspected motor mounts so I pulled off the hood and tried duplicating everything and didn't notice any movement in the engine, at least not an abnormal amount. I'm 75% certain it's suspension/mount related but it only happens at the time I mentioned above. Bumps or turns have no effect. My mechanic looked around and found nothing so I'm at a loss
85_305
Honda Civic (2001 - 2005)
41
Apr 26, 2021 07:43 AM
p1driftfiend
Dec 30, 2003 07:34 AM
geminis2k
Jan 28, 2003 01:27 PM
VTi NA
Feb 26, 2002 09:40 PM
