Header leak? Or wd40?
Old Aug 9, 2018 | 10:43 AM
moonchies's Avatar
Default Header leak? Or wd40?
I went to an exhaust shop to put in an aftermarket header, but it leaked so they had to put the stock one back on. I popped the hood when I got back home to make sure everything was okay and I saw some smoke coming from the header. When I called them they said it it probably the wd40. The car seemed like it ran fine. I also had a hi flow cat installed so I can't tell if it's louder cause of that or cause it's leaking. Am I just being paranoid?
Old Aug 9, 2018 | 10:52 AM
MotorMouth93's Avatar
10 Year Member
Default Re: Header leak? Or wd40?
I don't know why they'd use WD40 to install an exhaust manifold, but if it was WD40 it would all burn off within minutes. If the manifold is smoking where it meets the head for more than a few minutes, it's leaking.
Old Aug 9, 2018 | 10:54 AM
moonchies's Avatar
They used it to take off the stock one.
redDAinteg
Mar 5, 2009 05:23 PM
Stein
Aug 31, 2005 09:33 AM
976
Aug 20, 2004 10:26 AM
RUBZERK
Apr 2, 2004 11:09 PM
Brasspremier
May 3, 2003 04:06 PM
