My db1 92 integra problem, help please
Old Aug 9, 2018 | 02:47 AM
OgulcanTR's Avatar
Icon2 My db1 92 integra problem, help please
Hi, my db1 92 integra rpm clock not working..
The car is running, the rpm is not running. (indicator clock is new)
what is the problem?
Old Aug 9, 2018 | 06:15 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: My db1 92 integra problem, help please
Do you mean the gauge cluster is new? if so was it from the same year integra?
If your RPM is not working its most likely the signal coming from the distributer, Its usually a blue wire coming off the back of the plug on the distributor harness that plugs in the distributor.
Old Aug 21, 2018 | 10:50 AM
OgulcanTR's Avatar
Thanks for the answer, Ignition module output signal is not present.
I changed the ignition module.
Problem solved
repingjdm
May 13, 2010 09:43 PM
GSR4U2NV
May 17, 2006 01:35 PM
Built B18ABorC
Sep 9, 2004 11:43 AM
