Header bolt siezed & comletely stripped
Old Aug 8, 2018 | 08:51 PM
Just1nK4ng's Avatar
Default Header bolt siezed & comletely stripped
I am working on head gasket replace but got two bolts holding me back seized....
Should i cut the bolt off? top right one thats completely stripped?
Old Aug 9, 2018 | 03:23 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Header bolt siezed & comletely stripped
YES. Threads are jacked up. You can either replace it with header studs or bolts afterwards.
Old Aug 9, 2018 | 04:50 AM
tony_2018's Avatar
Fish Twig
amazing work.
Old Aug 9, 2018 | 06:46 AM
09chaplak's Avatar
Loves Tossing Salad
ROFLCOPTER. How the hell did that happen? Yea sure, cut off remove header, try to remove the remaining bits but good luck wit dat.
09chaplak's Avatar
Loves Tossing Salad
Looks like JB weld or some **** haha
Old Aug 9, 2018 | 07:22 AM
tony_2018's Avatar
Fish Twig
Thank god that never happened to me yet.
Old Aug 9, 2018 | 08:07 AM
NVturbo's Avatar
O.G. triple O.G.
more like vise grip pliers
Old Aug 9, 2018 | 04:13 PM
Just1nK4ng's Avatar
This ***** a nightmare
i used socket extractors
dermel
heat
I think low quality bolt was used and/or frozen
Time to just cut off the bolt....
Old Aug 9, 2018 | 04:29 PM
Just1nK4ng's Avatar
how?
By welding it?
Would it be okay with that bolt cut off?
Would it affect gasket
Old Aug 9, 2018 | 05:14 PM
mk378's Avatar
With the head off, you'd try to get the remaining part of the stud out and install a new one. If you're sending the head to a machine shop they can do that for you.
Old Aug 9, 2018 | 07:11 PM
Just1nK4ng's Avatar
i am still having issues with the middle bolt. I am thinking of cutting it off too
Old Aug 10, 2018 | 02:41 AM
NVturbo's Avatar
O.G. triple O.G.
cut them off and once the header is removed, you will have enough room get the damaged stud out
danteisme
Oct 14, 2006 10:36 AM
JohnQPublic
May 26, 2006 07:15 PM
gsrvx
Apr 19, 2005 06:21 AM
Ceeveek
Jul 19, 2003 10:14 AM
EF_LSVtec
Oct 3, 2002 06:30 AM
