Spark plug holes in valve cover are bent
Old Aug 6, 2018 | 04:39 PM
Alliekat's Avatar
Default Spark plug holes in valve cover are bent
So, I'm having a no-start issue with my 2000 civic DX. It tries to start, but won't catch. We did a compression test and 2 of the cylinders had low compression, so I was told this may be a timing issue. I did the timing belt and it didn't start, so I started from scratch and re-did it, but still the same result. When I pulled the valve cover off I noticed the metal where the spark plug holes are is warped. I was trying to replace the gaskets in each of the 4 spark plug holes, and they are bending in, a sort of rounded way so that I couldn't pull the gaskets out. I'm wondering if these being warped is a sign of a different issue. Does anybody know what this could mean? I tend to think this is an ominous sign, but any help is greatly appreciated!!
Old Aug 7, 2018 | 07:35 AM
0c00l's Avatar
Default Re: Spark plug holes in valve cover are bent
can you upload a few pics of what your talking about? If the sparkplugs go in and tighten up correctly then there shouldnt be an issue unless a couple valves were bent or the head gasket leaks.
Old Aug 7, 2018 | 11:02 AM
tony_2018's Avatar
Fish Twig
tubes don't have anything to do with your starting issue.
Old Aug 7, 2018 | 01:21 PM
eghatch9295's Avatar
Stancetard Hate Monger
if the cylinders low on compression are next to eachother, odds are you have a headgasket issue. time for a leakdown test.
KevinVX
27
Nov 9, 2014 03:50 AM
Mysticalmotion
Sep 20, 2009 12:35 PM
EK_B
Dec 31, 2007 11:13 AM
GARBhatch.
23
Jan 13, 2005 05:19 PM
mongoliandonuts
Jul 7, 2004 09:10 AM
