My Civic won’t idle correctly for a few seconds after Start.
My Civic won’t idle correctly for a few seconds after i start it, it almost dies out. After those few seconds it idles fine. This only happens when the engine is warm. It’s a Civic Coupe from 2004. Does anyone have an idea what that could be? (BTW, I’m from Germany and i moved a few months ago to the US so I’m sorry if my English is bad.)
I don’t have a Check engine light. But i noticed that this roblem only occurs when the steering wheel is straight. So maybe it has something to do with the power steering pump?
Hey there, I have the same problem intermittently in my car, the idle goes low at start up then returns to normal only for a second or two. Did you ever figure out or fix your problem? Thanks
