2006 Ridgeline dome light, not front map lights, but center cab roof lights... ... wil not turn off?
Just replaced instrament panel cover (twice), I forgot to replace the dash light dimmer switch wire 1st time. After replacement, dome light worked 1 time, faded to off perfect. When next the door opened, dome light on and will not turn off, manually or auto fade.
I am pulling bulbs so the battery won't die.
??? Any ideas?
It may be an issue with the interior light switch. First check the position of the switch.
Power is always hot (+) to the ceiling light. Ground (-) either via the door switch or Ground G402 needed to complete the circuit has to go through the interior light switch.
