GsR motor hitting hood
Old Aug 4, 2018 | 10:59 PM
805gt500's Avatar
Default GsR motor hitting hood
hello guys I know this topic has been beat to death but trying to clarify things. I just bought a 94 civic si hb w a car swap and it has hasport motor mounts. The valve cover seems to be hitting the hood. Did the previous owner get the wrong kit? Which ones exactly are needed? Im doo g a b18cR jdm swap within three weeks and want to make sure it sits right. Please let me know which ones exactly you guys are running with no issues. After the swap I want to get that hood fixed and painted. Thanks
Old Aug 5, 2018 | 05:23 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default Re: GsR motor hitting hood
might need to check your engine mounts and make sure they are not worn out or broke. I have the same swap and no problem. The only thing that ever hit my hood was my turbonetics wastegate on a cast drag manifold. Set your e brake and put your car in gear (forward and reverse ) and see if you have much engine movement as you start to release the clutch
Old Aug 5, 2018 | 07:15 AM
2x0's Avatar
2x0
10 Year Member
Hasports are unlikely to go bad, but doesn't hurt to check. Are you sure they are genuine hasports?
I have heard that in some cases, the webbing under the hood must be cut, or you can raise the rear of the hood with hinge spacers.
Old Aug 5, 2018 | 08:28 AM
805gt500's Avatar
I’ll check if they are going bad. They are hasports. I’ll check all of the mount make sure they are okay. Which ones exactly did u guys order from hasport name and stiffness of insert
Old Aug 5, 2018 | 08:31 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
I did my swap 15 years ago, so I can’t remember exactly what I have, we did not have as many options back then
Old Aug 5, 2018 | 08:36 AM
805gt500's Avatar
Well ur valve cover looks straight so it looks like there is no hitting. Do u have spacers etc
Old Aug 5, 2018 | 10:16 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
no
Old Aug 5, 2018 | 01:53 PM
tony_2018's Avatar
Fish Twig
Picture of motor mounts and picture of engine bay.
Old Aug 5, 2018 | 09:56 PM
805gt500's Avatar
Take a pic tomorrow
Old Aug 5, 2018 | 09:58 PM
tony_2018's Avatar
Fish Twig
I see you next yr.
Old Aug 7, 2018 | 01:22 PM
eghatch9295's Avatar
Stancetard Hate Monger
/\ lol. b swaps do not interfere with the hood on a civic. hasport, hardrace, oem combos, never seen an issue... unless the incorrect mounts are being used.
Old Aug 7, 2018 | 01:47 PM
805gt500's Avatar
Has all three hasport mounts I know the oem ones failed on him before swapping to hasport. Just want to make sure everything is solid before I put next motor in and take good to body shop for metal work n paint
Old Aug 7, 2018 | 01:48 PM
805gt500's Avatar
That motor n harness is going bye bye but want to make sure the next motor is good to go within the next two weeks. I guess I’ll have to see what’s going on with em see if the motor is moving while having brake up in first and rev etc ?
Old Aug 7, 2018 | 05:58 PM
a straight facing shot of the entire bay is what we're after.
Old Aug 7, 2018 | 06:40 PM
805gt500's Avatar
That’s the only shot I had on my phone I’m on my work days won’t be able to till sat
Old Aug 7, 2018 | 09:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Mine hit with stock mounts when I did my GSR swap back in '98. I trimmed and hammered up the under structure and it no longer hit. HASport mounts were no different.
Charlie Moua
13
Mar 1, 2011 05:22 PM
818wHtEG6
Jan 6, 2006 11:37 PM
JDM00SI
Nov 19, 2005 08:25 AM
yellowmonkeyboy
Jun 27, 2003 10:01 AM
1 speedstar
Sep 10, 2002 12:39 PM
