​​​​​​​D15 LOOSE TIMING GEAR, HELP!!
Old Aug 1, 2018 | 10:50 AM
JayDaTroll1's Avatar
Default ​​​​​​​D15 LOOSE TIMING GEAR, HELP!!
Is the slight space between the timing gear and the crankshaft key way NORMAL??
Old Aug 1, 2018 | 03:03 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: ​​​​​​​D15 LOOSE TIMING GEAR, HELP!!
I'll check and post a photo after I get home, assuming I remember. I am bad for forgetting. I got two blocks with cranks in my garage and the timing gear right there. Just gotta remember after work.
Old Aug 1, 2018 | 11:47 PM
Thanks man, I will be waiting patiently for your response my man!!
Old Aug 2, 2018 | 08:43 AM
What if I put some JB weld in there to close the gap and hold it tight in place??
Old Aug 2, 2018 | 01:49 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
JB weld is not strong enough.
On my D15B7 blocks there is not that gap or play. I took a look but didn't have my phone with me. I hope to get you a picture tonight.
The timing gear was a perfect fit on the snout.
Your timing gear looks more like the D16/D17 gears that have the crank position sensor.
Old Aug 2, 2018 | 09:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It is not normal... you will need to replace that crank gear. If a new one still has a significant gap, the key slot in the crankshaft snout is damaged and must either be welded and re-cut or the crank needs to be replaced.
Old Aug 3, 2018 | 12:11 AM
You are right about it having a crank position sensor, I am using a D15Z7 (D15B) 3-Stage VTEC motor.
Well I did replace the entire crankshaft cause my old crank key way got really battered and messed......so I have been struggling to find this timing gear because there are no spares here.
But hopefully they can do some sort of wizardry at the engineering shop for me to remove that play AND get the actual crank key made!!
I will keep you guys posted!!
chitty024
Feb 28, 2008 03:13 PM
downeyballz
Jun 6, 2005 04:34 PM
downeyballz
Jun 6, 2005 11:10 AM
Lucky_Smurf
May 27, 2005 11:01 AM
